Woods Cams--tw555--and valve noise
I'm thinking of installing them in this new ride over the 255's.
I have a TW6-6 cam set on my RKC and I don't hear extra noise - I'm on standard lifters and Andrews pushrods. Maybe I might if I had a batwing bike. Some say that a Woods cam is a lot quieter if the pre-load on the pushrod is increased by a couple of flats but I'm not an expert so I'd talk to someone who knows the details before you did that
The Wood's TW-555 cams are generally very quiet, in fact many times they are quieter than stock especially when used with the Woods Directional directional lifters. I'm not sure where the "noisy" Wood's cam info being passed around forums started from, but I have a pretty good idea. We have installed many, many of these cams and the most important consideration is pushrod adjustment, if you do not have them in the correct area of the plunger travel you may see excessive noise. I highly recommend adjustable pushrods as the base circle is slighly different than the stock cams, if the lifter preload is not correct this could lead to noise. Some have noted overly aggressive ramps, and while Wood's does make some pretty aggressive cams with up to .650 lift the TW-555's have very conservative ramps and overall specs. They are actually less aggressive than ramps on the stock cams. The photo below compares the stock and Wood TW-555 cams
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
I gotta say that based on that pic the 555 cams have much more aggressive ramps then the stock. It is clear that they open faster, and stay open longer looking at that picture.
I have run the 555 in 2 different bikes and setup with Woods lifters they have been very close to stock in valve train noise, but they do seem to have slightly different sound. I also have run the Woods 7 in a different setup and they were pretty loud. It does seem to make a major difference if you install them with more preload and the Woods lifters, otherwise you may very well HEAR them.
I do have to say that the 555 cam performs very well when dialed in, they just keep on pulling.
Hobe
Hobe
TW555, woods directional lifters, & FM push rods (plus PCV and Stage 1 intake/exhaust). Get a slight tick when engine is bone cold that goes away very quickly. After that, valve train is quieter then stock. In the heat and humidity of VA, I had pinging <3K form the FM base map for my PCV. I removed the 2-3 degrees of advance in the 2500-3000 rpm range and it runs great. Very quiet, even with lower fairings on... well except for an awesome lope and that it seriously pulls now. Don't even notice mountain passes or loaded bike and passenger anymore. 40-42mpg.
Originally Posted by springer
Traveler, I have been admiring your bike for a while now. Who made your seat???
I have one just like it; it came off an '02 FLHT. I think it will fit later models but not sure. My butt can't take for more than 100 miles but it sure looks good; I will let it go cheap. PM me if interested and I will send you a pic.
As far as valve train noise, it's reminds me of the same conversation when everybody was installing gear drives. Some guys would go back to chain drives because they couldn't handle the noise and some would say the gears made less noise than stock and some would say the gears made noise but they liked the noise. Sure, the noise would vary depending on how the gear drives were setup but noise is pretty subjective; what't noisy to one will be acceptable to another.
