Hydraulic Clutch
Old Sep 9, 2011 | 07:46 PM
b1rider's Avatar
b1rider
Default Hydraulic Clutch
I would like to install a Hydraulic Clutch on my '11 Limited. Is that possible (I guess anything is possible) and what kind of cost am I looking at? I have arthritis in my hand and pulling the clutch in hurts until I ride awhile.
Old Sep 9, 2011 | 07:58 PM
Dallas 13's Avatar
Dallas 13
J&P Cycles has a kit from $230 and up. Not sure how much relief it will give you, and it's one more fluid to keep track of.
Old Sep 9, 2011 | 08:02 PM
KCFLHRC's Avatar
KCFLHRC
Had a hydraulic clutch on my Yamaha Roadliner, it was awesome. I think it would help you.
Old Sep 9, 2011 | 10:40 PM
heavymetalthunder's Avatar
heavymetalthunder
I've got an hydraulic clutch on my Road glide and I think its harder to pull in than alot of cable clutches I've tried. The hydraulic clutch that was on my gold wing was much easier to use than the 1 on this Harley is. Its hard to keep it pulled in sitting at lights. You might try 1 at demo days before deciding. The demo days around here have the 2012 CVO Road Glide to test ride. Hope it works out for you.
Old Sep 10, 2011 | 12:27 AM
drukanfu's Avatar
drukanfu
Try some teflon dry lube spray or one of these cables first. Barnett cables are smooth working, long lasting and are made with the finest components available, making them virtually indestructible
Stainless steel cables with clear coating offer that custom look without the fear of damaging areas that the cables come in contact with
Easy-pull high-efficiency design reduces lever effort by up to 40%
Made in the U.S.A.http://www.barnettcables.com/service...aspx?faq_id=22
Old Sep 10, 2011 | 12:30 AM
BackRoader's Avatar
BackRoader
Order some inox and lube it up.
Old Sep 10, 2011 | 04:48 AM
vzts4q's Avatar
vzts4q
I did it on my 08 Ultra. But I did it for looks as much as anything just like the symmetrical look of a master cylinder on both sides.
Not really much if any difference in the pull as i recall.
Back when I did the same change on my 02 HD offered a kit they don't do that anymore.
You can just order from the CVO parts book if you want to change to a chrome master cylinder. If you want to keep it black the V-Rod master cylinder will work.
Do a search here you will probably find more current info than I have.
Old Sep 10, 2011 | 05:08 AM
Stiggy's Avatar
Stiggy
I've never found a hydraulic unit that was easier to pull than a cable style either...Sorry
Old Sep 10, 2011 | 05:39 AM
Jinks's Avatar
Jinks
I have one on my '07. The pull is 10-15% easier than a well lubed cable, but the engagement is 100% smoother. The big plus for hydraulic clutches is the reduction in maintenance. No more lubing or adjusting cables, & no more adjusting clutches. As vzts4q (?) said, the CVO bikes come standard with hydraulic & their chrome parts will work on yours. Vrod hydraulic clutch master cylinders are black if you don't want chrome. No need to wait for a demo, just go to your local dealer & try the pull on one on the sales floor.
Old Sep 10, 2011 | 06:08 AM
geezer glide 56's Avatar
geezer glide 56
You might want to see if the dealer will install a diaphragm spring from a 96" in the clutch pack...It should pull easier.
