HELP! CAM Bearing info
My friend purchased a new 2011 Ultra Limited with 103 motor last Saturday.
This morning as we speak the dealer is installing Stage 1, 254E cam SERT Pro.
I noticed that the cam Kit did not include new inner CAM bearings I told him to ask the dealer to install Torrington or SE which I think are torrington..?? Anyway the dealership told him that the "new" bikes already have the SE bearing. I don't think that is true, can anyone verify this for me...please.
if it doesn't matter then why do they make a bearing with nearly twice as many rollers?
And if you are going to open the CAM case and install new cams and there is a better bearing available why wouldn't you install it?? And your right, it PROBABLY wont matter but, I wanted to know if the stock bearings had been upgraded to SE??
I'm in the process of installing S&S 510 cams. Replacing the stock cam bearings with Torringtons. This was recommended by the mech I use for things like this.
His words, "I want to replace the Chinese Harley bearings with Torringtons while I'm in there". I will look at the bearings when we get them out and see exactly what they are and let you know.
The bike is a new 2012 EG Classic 103. He is the best Harley mech/tech that I have ever known and I trust his judgment. He does not push unnecessary parts and service onto customers. His cam and bearing replacements with a typical stage I pipes, cleaner, and tune runs around $2000. This is using quality American made parts. Harley quoted me $3200 for the same service (keeping the stock bearings) and using HD replacement parts.
No brainer for me.
No brainer for me.
No brainer for me.
No brainer for me.
The 2011 Limited has the 9215 (caged INA) bearing.
A set of the B168 bearings costs about 15 bucks.
I swapped over to the full complement bearings when I did a cam swap on my motor last year. However, I don't think they're actually an upgrade. ( Caged bearings are rated for higher rpms, full complement bearings are designed for higher side loads.) Most folks, including all the professional engine builders I know disagree with me and recommend the bearing upgrade.
