dtc codes problems
Old Sep 25, 2011 | 04:45 PM
keith t's Avatar
keith t
Default dtc codes problems
I have an 09 Ultra that has recently had some work done, some by me and some at the dealer. Installed the boom amp, oil temp gauge, and custom aulilliary light kit for the passing lamps. I did this while the wheels were off for tires. I decided to replace the wheel bearings and the indy with the tires put the wrong L F bearing in (I have ABS) and I didn't know why the front pads were dragging and ended up sending the bike to the nearby dealer. So they fixed the bearings but have slightly warped rotors they said, but said I could handle that later down the line. Today I go about 60 miles one way, not noticing anything odd but on the way back after about a couple hour break, the ABS light comes on, not flashing, and the volts drop to about 8 along the way. Codes say, first P PO 132, second P PO 52, then none, none, none and the last one, I guess its a b says CO 562. Can't find the b code listed anywhere so am wondering if someone can help.
Thanks
put this on the dyi side but haven't seen a reply
Old Sep 25, 2011 | 05:01 PM
Dionicio's Avatar
Dionicio
PO132 means Front Cylinder running Rich. Can't find PO52, Maybe it's PO152 Which means Rear Cylinder Running Rich. CO562, device running low, a low voltage condition prevents the ABS from operating properly. Hope this Helps. Try to find the cause of the voltage drop, fixing it may solve all Your problems.
hdmg
May 26, 2013 10:15 AM
1690Mike1
Sep 14, 2012 03:47 PM
keith t
General Topics/Tech Tips
Sep 25, 2011 03:22 PM
Bfazona
Jul 21, 2011 09:18 AM
threeten
Sep 11, 2010 07:55 PM
