Wiring GPS power on Road King Classic
Wanna use my GPS on my 02 RK Classic. I don't have anything wired to my accessory switch, but I have also heard that I can use the wiring for the unused fender tip light in the Classic highlight housing. Can anyone help me out and let me know how you got power to your GPS. Pictures and full explanation would be great.
Thanks!
Thanks!
My buddy and I installed my Garmin 550 on my 2012 RKC recently. After bantering about ideas involving accessory lines, we just ran the power from the handlebar mounted unit through the front trim and then straight under the instrument panel and speedometer and right under seat to battery. Looks clean as a whistle.
Most RK Classics have the same wiring harness as models with the front fender light even though there is not one on the Classic. On my 2005 there is a hot wire and a ground inside the headlight housing, spade terminals. That's where I pulled power for my GPS. I read this bit of info on a forum somewhere and I just poked around inside the housing with a test light until I found what I was looking for.
Thanks!
I am going to wire one of these up over the winter.
http://www.3brpowersports.com/products_TAPP.htm
It will be much more versatile then hardwiring the power source for one device.
I wired a black Bell cig lighter ($19) from auto zone and mounted it to the frame with zip ties - very solid. Since it's black, you can't tell it's even there unless you look very closely. I plug in my GPS with car charger when needed, which has traffic avoidance so it uses the car charger cord as FM antenna to receive traffic info... what's nice about having the cig lighter charger is you can also charge phone, ipod, whatever... I tapped into the front running lights in the headlight nacelle if I remember correctly... can't remember off hand. Cables are run up the frame in small black plastic wire conduit, so looks good, but is also hidden along the frame up to the nacelle.
