Primary cover gasket
1st off, posting here because I know it will be seen/answered. I have the type primary cover that uses the round cardboard type gasket with silicone type sealing. Can these be re-used or should I just buy a new one when I change my primary fluid this fall?
buy a new one
buy a new one... less than $2
reuse it, if it leaks then replace it. they're good for more than 1 use.
I've reused mine with good success.
you might get away with it, you may not. I always love doing the same job over , because of a 3.00 gasket. Let me put it to you this way, I don't think any professional mechanic would use it over again, that said do what ever your heart tells you
by the way, I am a professional mechanic
Where are you all getting these gaskets for $3 bucks? My dealer has them around $11.
That said, I'll be replacing them. $11 is still less expensive to me that having more Redline shipped, and disposing of the old stuff twice cause of a leaky gasket that I reused. |
Replace it instead of taking the risk that it might not leak....If it leaks, you'll be pissed doing the same job over again.
$2? $3? HUH?
When you pull it, if it looks 'good enough' it probably is. |
© 2024 MH Sub I, LLC dba Internet Brands
