Changing the Gauge Lights to LED's
My 10 Limited tach and speedo are led lights but the other 4 are not. There is a very noticeable difference in the color of the light. Which led's are you going with? I was on Superbrights website and there are quite a few different types that replace the 158 bulb.
How many lights are in the 4 guages?
Thanks in advance
There is 1 #158 bulb in each gauge. I have ordered the WLED-(x)5 in (x=R for Red) and also the WLED-(x)HP5, also in Red. The HP is suppose to be even brighter the the WLED-X5. The regular WLED-x5 is non polarized so it doesn't matter which way you insert the LED. The HP's are polarized so if it doesn't first work remove the bulb and reverse it. On each bulb you'll have to pull out the little wire from the wedge just a bit to make proper contact with the receptacle. I've order 2 extra bulbs of each as a spare and just in case I've got a defective delivery.
I choose red so that it will match the light from the radio. The tack and speedo are both on the amber side and since I wasn't changing them I decided to match the color of the radio with the gauges.
I see you're from the Steel City. What part? I'm from the South Hills by Whitehall and Castle Shannon area.
Hey thanks for the reply. I am going to order some white led's so my 4 guages match the tach and speedo. When looking at their site they have a few different view angles, 32, 90 and 120. And they have cool white, warm white and natural white... ughhh. I just want to make sure what ever I order works correctly.
I also just noticed your from the Burgh. I live in the North Hills not far from North Park and Ross Park Mall. How does you bike run with the cams? I have a mostly stock 103 and have been on the fence about a set of cams.
John
John
John
Who is doing your 103 and cams? I never dealt with Zanotti. Bought two bikes from Three Rivers, will never deal with them again. Now I deal with Hot Metal HD or Highland HD and couldn't be happier.
Bike is up at Hot Metal. Been doing business with AJ back when it was Heritage HD. Had Hot Metal do my V & H Power Dual Headers along with installing the HD Touring Pullback Bars. Very pleased with their work. Decided to go with the 255 Cam because I do a good bit of 2up riding and felt the other Cams, both HD259e and Woods 555 or 777 were more mid to top end Cams as compared to the 255 Tree Trunk Pulling Cam. Now that I've completed my life cycle by moving up to the Ultra from my 97 RK my days of running the bike up to 120mph have been satisfied. Now I'm just looking for the seat of the pants, hold the handlebar, feel my head drift back from hard pulling torque on the low end plus add a little more HP by moving up to 103".
