I have recently purchased this bike from a local dealer and I have rode everyday since. It runs good except on an occasional warm start it will run for a couple seconds then shut off, but starts right back up. I took a video clip of this for y'all to hear. My other question is does it sound to y'all like it has a different cam. I have listened to others that have cams and it sounds like them. The bike has 24,800 miles http://www.youtube.com/watch?v=Wb7_O...e_gdata_player
The bike was synopses tuned previously before I owned it should I have it retuned or purchase a PCV. My plan is to add a cam and possibly 107 kit sometime this year
Tuning...also have them check this idle and fuel pump. Not to worry.
dyno time for sure ,u already have sert? hope u got the disc and cable with the bike since its been on the dyne at least once b4,and it has a tune problem look for a well known tuner,not the same dealer u got it at as they likely did the tune in the first place.
I was told by dealer it had one it didn't come with a cable that's why I asked about the power commander. I know it has been tuned because of the 6200 redline does the bike sound stock to y'all it has a choppy idle compared to my 08 fxdl
without the cable your screwed,it is possible it was a stg1 download(but unlikely).u would have to have the dealer flash it back to stock, tuning with a power commander could probably be done but with the ecm already changed a canned map is not going to work.
