Adding Air Temp & Oil pressure Gauges to 2003 Electra Glide Standard
This is the sending unit, oil pressure, it is located on my bike bottom right front of the crank case. Very hard to get to. It is so close to the crank case I wonder if that kind of heat would hurt the crank case. As much as I hate to do I may end up at the Harley shop. I'm sure they run across this from time to time. If I mess the end of it up to bad I will be up **** creek then.
take the floorboard off and the brake lever. Once you can do this you can get a pair of vice grips in enough to unscrew the sender unit. it will bugger it up but hey, you are not going to reuse it any way, you will need to pull down in small increments. then when you install the new one, you can screw it in by hand up until you need to tighten, then either a very long big wrench or the aforementioned vice grips can tighten it up. No it will not hurt to start it unplugged. However dont start it with the sending unit unscrewed as oil will shoot out.
I just did this on my 04 road king i converted to a road glide. it should be no problem
Using a little heat from a small hand held torch will not hurt the crank case, apply the heat to the sending unit near the case, but not on the case, try working the sending unit back and forth until it will free up, if it doesn't use some Kroil Penetrating Oil at the threads and let it sit overnight, Kroil is some mean stuff that will work it's way into the threads, I've used this stuff for years as an automotive tech.
X2 spray it up.
