Who wants their Ricor Intiminators to work better?
#581
yeah, new seals and bushings. figured i might as well do it all while i have it apart putting the new powdered lower legs on and doing the springs etv.
#583
I haven't read the recent posts on this thread to see what's up, so apologies if I'm not responsive. However, I do have some useful info to share:
A few years ago I installed the CCE upper clamp, ricor valves tweaked by fabrik8r, and race tech springs. I weigh ~200 and always ride solo. My spacer was cut to provide 39 mm of preload; oil level set as per manual. 39 mm was too much preload. My front end was stiff and I had an occasional, super annoying clunk that occurred on quick extensions of the forks. I recently changed oil and reduced preload to 34mm. Much better!. The clunk is gone and ride is much better. Improvement was so pronounced that I'm going to reduce by a few more mm. (One of us - fabrik8r - rightly said it gets easier every time you take it apart.)
Still swear by the CCE clamp for all pre-rushmore front-ends.
Jef
Jef
#584
#586
Also curious who else has done this and is around 180lbs to get a starting point. Thanks!
#587
Diameter
Just realized...when I asked for PVC size, i meant diameter. I know Ill have to measure and test for length.
Does anyone know the diameter of the PVC spacer I need to fit inside the fork tube so I can grab it before pulling my forks apart? Just enough to fit in 41mm or is it specific? Thanks!
#588
#589
This thread seems to have died which is a bummer cause theres a ton of good info here.
But anyway, I dove into my forks this weekend for the first time, to install my Rt springs and modded ricor valves.
With all the info here and a couple youtube videos, it was all pretty straight forward to disassemble and replace seals/bushings.
I weigh 180 and got 1.0kg springs, 2008 road glide.
If my math is correct I got 4" for a spacer. Putting the caps back on was tough but I got them screwed in after a few tries and another set of hands!
I'm still waiting for my front wheel from powdercoat so I wasn't able to take my sag measurements yet, but I'm hoping its close to where it needs to be.
My fully extended travel was like 3/4" less than most in here which I found odd.
The one thing I didn't understand and couldn't find was about oil amount/oil level.
Can anyone point me to the page or post that explains where that's supposed to be? I put 10.8oz in each leg as the manual states but then I remembered guys talking about measurements and sucking some out. I think I messed that up?
The bike has 32k on it and I have no idea about its history. One legs oil came out fresh and bright red, and the other leg was black oil. Thought that was strange. But oh well, at least I know what's in it now.
#590
Unfortunately fabrik8r went off to a new line of work that took him away from us, so we no longer have the original author to keep us up to date, but it's an oldie and a goodie, which keeps giving! I ran a set of his Intiminators for a time, while Jason was still active, but to be honest don't recall anything special about oil level. There is a post at #419 on levels, quite probably others.
Puglia10 (04-10-2018)
