cam bearing failure
thanks guys...So what I am hearing is there is nothing wrong with the original type bearings and people are just switching to the torringtons because they are cheap and it is good practice to change bearings at cam change...the original bearings are fine, i.e. no failure issues....
That being said I also have no expereance with faliure to the stock bearings.
I did mine the other way around.
I had a buddy with an '03 Heritage grenade his inner cam bearings. On my '03 FLHRCI, I was sitting on some Chrome Cash and wanted to put in the hydraulic cam chain tensioner plate with that, and take care of the inner bearings at the same time. So..... "while we were in there". That led to SE211 cams too, just for kicks.
I decided that since I was spending "funny money" I might as well fix all that stuff on my schedule, rather than not.
Just my .02
Just my .02
Resources close to the Source tell me years back when MoCo switched to the cheaper style bearings they saved $8 per motorcycle. There was an argument on the inside that those bearings were destined to fail at 40k miles and not worth the $8 savings.
Guess what, 40k miles is well outside what most people will drive while under their warranty and repairs after warranty are even better for the bottom line. So cheap bearings for us it is.
Assuming those bearings are reliable is a gamble where the odds get worse with time.
Considering that a catastrophic engine failure is imminent from a a bad cam bearing, it's really just another cost effective PM that needs to be on the to do list, especially when you are in that area wrenching.
