Belt Drives Inc. How long is fair?
I took your advice and ordered iy up here I had to go to a small Inde, and got it today and he ordered through Mid USA supply.
iT'S INSTALLED ALREADY.
Also THANK-YOU FOR THE ADVICE.
Mid usa # 77560. If your on BDL's site you can cross reference close to the bottom of the page.
I should have added the HD p/n as well. 40040-05 And at least one HD supply reference:
http://www.latus-harley-davidson.com...x=14&btnG.y=15
BELT, REAR DRIVE, 139 TOOTH, 40040-05, BELT, REAR DRIVE, 139 TOOTH
The thing is I want the Gates Poly Chain 139T x 1" belt (PC-139-1), and from when I checked before, I thought they are the only ones that sold them. I'm gonna check again, because that doesn't seem right.
The only other options are the Drag Specialties, Falcon, and some other one, but on the CVO board there were some guys who had some of these belts break on them, but none of them were the Gates, plus Gates is the mfg for the OEM HD belts, so I don't want another brand.
Some guys keep suggesting various HD belts but HD does not make a 139T in a 1" width, so the only option is the aftermarket.
Thanks for the info on this vendor- I'll have to see who else sells them.
Never mind- I see Badgerbob mentioned Mid USA has them. I found these guys sell them at a good discount- only $115.78
http://www.legendmcs.com/mid-usa-har...lts-parts.html
Hopefully they're a reputable vendor.
