Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   Help installing Rush TD's (https://www.hdforums.com/forum/touring-models/730187-help-installing-rush-tds.html)
DeneFXDWG Feb 3, 2012 11:29 PM
Since the company is closed tonight and for the weekend I'm asking anyone's help in installing a new set of true duals on my '11 FLHR. Got the old system off and installed the O2 sensors and was ready to mock up the new ceramic pipes on the bike. Rear cylinder looks pretty straightforward. Instructions say that the front header is supposed to be supported by the bracket that is under the tranny, (stock tranny bracket), using supplied brackets 023 and 024 and a couple of flange bolts. There is absolutely nothing on the header pipe to fasten to. I'm thinking the factory forgot to weld a receiver flange to bolt to the tranny bracket. Does anybody out there have this system they can run out and look at their bike and see if it is in fact supported under the tranny and also in middle of the rear where the stock cross pipe was fastened, (there is a female threaded hole there to mount it too but nothing under the tranny. Thanks
txfxstrider Feb 4, 2012 12:30 AM
Don't know about your model but on my '07 there is an exhaust bracket and a separate clamp that attaches under the tranny. The clamp slips onto the header pipe and bolts to the bracket. Did you have one on your stock header? If so, reuse it. Good luck.
DeneFXDWG Feb 4, 2012 10:35 AM
I do have one on the stock header but it's a welded tab w/ slot. Thanks
© 2026 MH Sub I, LLC dba Internet Brands
