01 Ultra Classic, I want to be able to turn lights off.
I have a 01 ultra classic and I want to be able to turn the lights off when starting the bike. Or when doing other things.
On my 89 FXRS it was only a jumper wire on the ignition switch. I was thinking that I would turn my lights on with the Ultra Classic at the Aux switch if I could figure out where to cut and splice? |
see if any of this helps:
https://www.hdforums.com/forum/evo-c...ng-96-flh.html On my evo bagger, i had a relay cutting out the power to the lights when the starter was operated. mike |
I did not see my light cut out. Although it is a new bike to me.
I want to be able to turn on my light when I want to. What wire on my bike do I cut and place a switch on. I cannot believe that I am the first to think about this. |
You cut your live wire & run it to a relay & power the relay from your fuse box. You also run an on/off switch into it.
Hatch. |
The circuit is powered in the fuse box, look for the Headlamp Fuse, it is powered when the ignition is powered up, you should be able to splice it to a switch from there and still retain the fuse in the circuit.
Originally Posted by mkguitar
(Post 9370750)
https://www.hdforums.com/forum/evo-c...ng-96-flh.html On my evo bagger, i had a relay cutting out the power to the lights when the starter was operated. mike Thank you, I did do that on my Evo. Simple matter of just cutting a jumper wire. But my 01 Bagger ignition switch does not have a lights on switch position. (That I could feel.) So I guess I will need to wire the light to a Aux switch. If I could only figure out where to cut and wire a switch for lights. Screw the Federal Law that makes Mfg. tell us to keep your lights on. If my voltage regulator dies and I need to make it home I want a fair chance to make it home. So far has happened to me three times on my Evo. Federal goverment should of also made kick starters mandatory. |
Originally Posted by pswomack
(Post 9372042)
Any idea what wire to cut and splice in my cowl to run to a switch? I have read the wiring scematics and cannot figure this out. |
I wouldn't advise cutting it in the fairing, use the existing wires in the fuse panel, you want that on a fused circuit with a relay for fail-safe reasons, not doing so could result in catastrophic electrical damage.
(Post 9372154)
Anyone that knows and can help. |
A plug and play way is a kit from Easternbeaver, their H4 Dual Headlight Relay Kit with FULL On/Off Switching. I have used these in several Harleys, since I usually upgrade the bulbs and don't want to pull the extra amps through the plastic bulb sockets or the high beam switch. I have one on my RG now, so I can cut the headlights off. I put the switch in one of the gloveboxes.
http://www.easternbeaver.com/Main/Pr...s/h4_kits.html |
© 2024 MH Sub I, LLC dba Internet Brands
