Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   Up Date on DIY Mod's (https://www.hdforums.com/forum/touring-models/733208-up-date-on-diy-mods.html)
DXHD $100 Feb 13, 2012 12:13 PM
In the DIY Mods &Tricks to Save section there are 941 threads and almost all are interesting. Out of the 941 half are about Garage Door Opener. So needing one I went with the one that used an odometer switch which I solder on my opener and I mounted the switch on my inner fairing opposite of my actual odometer button. I then secure the opener to the top of my radio with velcro where I thought it would be a good solid place, push the button and it worked great I put everything back together and backed out to go for a ride. I hit the botton and nothing then I rode back in and it worked. Well after a few Beers and a lot of words I will not bore you with, I took it back apart outside this time. What I found was if I took it off the radio it would work so not being an Electronic Eng. I quest it something to with the metal radio housing interfering with the waves. Just thought I would past this on just incase there or other electronically challenged people on the Forum
05 Ultra Feb 13, 2012 10:11 PM
1 Attachment(s)
Pic is from how I fixed the bracket, but you can see where I put my remote. I can open the GD from 3 houses away.
DXHD $100 Feb 14, 2012 06:45 AM
Thanks I velcro and then strapped mine to the Elect. Harness I thought this would cut down on the vibration. My driveway is 1/10 of a mile long and cover with trees, it works now as soon as I clear the trees.
rjmac53 Feb 14, 2012 07:28 AM
good for you..
© 2026 MH Sub I, LLC dba Internet Brands
