love jug cooling fan?
#121
The fancy one looks tight, but the other one looks like it might work.
Yes/No/Maybe?
#122
The mounting brackets on a Mini Beast just don't line up with the rubber mount for the horn. You'd have to drop the mini beasts down about 3 or 4 inches with a straight bracket and mount it much lower and to me it looks ridiculous there.
#123
got it, that sucks. Thanks
#124
You can check this thread for info...
https://www.hdforums.com/forum/gener...ing-fan-2.html
#125
I customized my mounting bracket to fit my wolo horn. Now I have the newer HD horn. Both fit fine. Not sure of the dimensions of the MB2 horn but just sharing in the event you can make it work.
#126
Installing with the wolo is totally different than installing the mini beast, which is a wolo with a cover on it. The wolo is mounted inside the cover and has a different bracket system to mount to the rubber stud. And honestly I'm not a fan of the way The Wolo looks on the bike. I originally did it that way years ago but the plastic on the wolo wears off and scratches easily.
I hate anything plastic so I removed the wolo although mine was still in excellent condition. Installed a HD loud side mount horn and 2017 touring horn cover....very loud, comparable to the wolo but much better looking.
#127
Received 3,931 Likes
Regarding Mini-Beast horns, there are some Love Jug Customers that have used the MB with the LJ's. Give BuyLoveJugs.com an email or a call at (346-800-7946) and they will be able to give you some options.
#128
#129
Check out this thread - post #52 for vid of horn
Deleted sound vid - did not even sound like the horn and did not do it justice.
#130
They are surprisingly very loud....louder than I expected. IMO comparable to the bad boy wolo air horn. Perhaps I need a sound vid of the horn....if I do, I will post on my love jugs thread.
https://www.hdforums.com/forum/gener...ing-fan-6.html
