Air shock presure question.
So how much should i be running in the shocks with the wife on back, she's "thick" lol
08 Ultra, i run as high as 46 psi. Depends,loaded and off to see this beautiful country, then it's around 44 to 46.
Originally Posted by cherry bomb
(Post 9424664)
(Post 9424664)
My book says at GVWR dont put in no more than 20-35 ....So is that BS? Riding 2 up and both far from "skinny" should i run around 40-45 psi?
07 SG I run 30-35 lbs 2-up
Originally Posted by TWIN CAM 96
(Post 9425175)
What kinda load you pulling lol |
depends on year/model- best to look in the manual and adjust the pressure so that the shocks do not "top out" or bottom out.
marvo post year/model when asking questions. specs do change Mike |
I know this is not the answer you want to hear, but trial and error is the best way to find what works for you. Even a pound or 2 makes a difference. I ride solo 99% of the time, and found that 14 lbs is the magic number for me.
Your 04 will have the same shocks as my 06. the newer models need more PSI to get the same results. |
07 UC 34 psi.
© 2024 MH Sub I, LLC dba Internet Brands
