low RPM Engine Vibration...Help
So i bought my bike about a 1.5 months ago 2010 FLHX 2580mi it now has 2900mi
has a SE 1 air filter,Rinehart slip on, SE Tuner, i noticed a vibration start
on a ride and didnt think much of it just thought it was a harley,well i was
trying a new seat w/sissy bar with the wife and she pointed out the
vibration also drove to work had a buddy take it for a quik ride and he
deffinitly felt it. It is the worse from 1500-1800rpm and it is engine for
sure. i can pull the clutch in and it goes away and i feel it more on a decel.
I checked the motor mounts,exhaust for rubbing,wheel weights, it has the
408 front tire. just looking for some insight before i take it to the dealer. thanks in advace!!
__________________
__________________
1500-1800 rpm is too low unless you are rolling down a hill.
at that motor speed oil pressure and volume is low. oil not only lubricates the turning assemblies but is also part of the cooling system, removing heat from the hottest parts of the motor ( pistons, heads) and carrying that heat away.
try operating the bike in a higher rpm range- for instance I shift to 6th gear at 65 or 70 mph on level ground, if on a grade, I'd stay in 5th until the speed is higher or the road flatter.
See if that affects what you are experiencing
persistent low rpm operation can destroy the lower end bearings and continually shocks the driveline, comp sprocket ( made to absorb these pulses) primary chain and tensioner, clutch, tranny internals, rear belt and ids can all be worn to the point of replacement.
If riding with other bikes ( experienced riders), you'll know if you revs are matched as the motors will "thrum" much like a multiengine piston powered bomber, on which motor speeds were often adjusted by ear and until vibrations through the airframe were reduced
pulling in the clutch does pretty much rule out any chassis problems, with the clutch pulled in, rev the motor and what happens?
Mike
Mike
