Can't find the oil leak
I see that some dirty oil is dripping off the bottom of the primary cover. I can't seem to find where it is coming from. We changed the inner primary seal even though it didn't look bad and re-installed. It is hard to say what the oil is, primary, transmission, or engine.
Now I'm wondering if it is coming from the other side of the bike and running across the crossmember on the frame.
Difficult to see where it is coming from. We were sure it was the inner primary seal, but there was no indication to support that other than that is where the excess oil was. I guess I wondering if it came from somewhere else and ended up there.
We did just install a Baker tranny, so that was why we thought it might be the inner primary seal. Changing that did not fix the problem though. It didn't leak before the tranny change over.
If not the inner primary seal, any ideas on what else it could be?
Any ideas?
Thanks!
Any ideas?
Thanks!
I am getting the same thing, I installed a stage 1 kit last summer and an oil cooler and now I am getting a little bit but I only notice it on the lower side of the bike when it sits on the Jiffy Stand but I have wiped everything down a number of times. I am thinking it is coming out of the air cleaner and somehow dribbling down and over to the low side. When I pull the ac off there is a little bit of oil on it. Makes me crazy trying to find the leak.
Received 70,392 Likes
You wouldn't believe the mess this made under my bike before I found it. Did some searches on the forums about leaks and this are comes up A LOT!!! Can't believe its not a recall. I believe its the connecter that goes to the stator. Under your ol filter beside the shifter side of the bike. This little gap let the whole bottom of my bike get covered, and everything a round it making it hard to find. At first it was just a pesky drop here and there that I would see under my primary. I tightened dowm the primary drain plug and primary bolts, took off the oil filter to make sure I didn't have two or no oil filter gaskets.
I did the messes fix and added black Silicone around it, its out of the way so you can't see it and the leak is gone.
Try taking a look. If your bike is under warranty the deal might fix it.
