changing oil at 500 milrs
I would change it with dino oil and then syn at 1000 miles. I changed mine at 300 miles on my new build and that oil was nasty! Have dino back in and after another 300 miles it still looks clean. For the money why take a chance??
The oil change intervals that I subscribe to are 50, 500, 1,000 and every 2,500 thereafter. This is what S&S recommends for their motors and I think it would be what Harley’s engineers might recommend if not for the marketing department. (My opinion only)
Did you install the PCV yourself...or the dealer? Were the O2 sensors disconnected? If they are still connected, the ECM is still trying to operate in closed -loop mode and will throw off the PCV maps completely.
If they are disconnected, perhaps the map needs a little enleanment in the 0% column. JMTC.
really? don't you get tired of trying to push that chain up hill? because our bikes have 3 separate reservoirs for oil, there is no reason that you can't use 'automotive' oil in the engine on your bike. in fact, your own owners manual will tell you to use diesel oil rated at sh, ch-4, ci-4, and cj-4. of course they want you to switch back to genuine hd oil at the earliest opportunity, but that is out of marketing, not necessity.
mobil 1 15-50 (which is an automotive oil) is rated at SN, SM, SL, and SJ. so it surpasses that rating that your own owner's manual tells you. and it works just fine in a v twin engine.
That said, I admit to being **** about oil changes. I changed mine at 100 miles, 500 miles, 1000 miles and usually every 3000 after that, but on long trips it has gone 5,000 a few times. Always synthetic, usually syn3 or Mobil1 v-twin, but if I can't find one of those I have used other brands of 20-50 synth. 130,000 miles on it now, zero motor problems, still running strong.
