Need feed back on progressive shocks
My buddy ask me if I could install a set of progressive shocks he needs to lower his bike a inch its a 09 HD Ultra . My question is which model should he purchase he would like to still keep a good ride without over paying . PS he is a big guy so doesnt want the bike bottom out on rough rodes..Joe Dolci
940's
No doubt 440s HD. Match it up with a set of their monotubes in standard height and install with both C clips per instructions.
940's are going to behave, in terms of 'stiffness' , similar to the 440's with heavy-duty springs. If your friend is over 200 pounds (I think the recommendation by Progressive is somewhere around 215/225), or rides a lot 2-up, heavy-duty springs on the 440's are recommended to avoid bottoming-out).
I have 940's. (I ended up getting lighter springs installed by Progressive on them, to soften the ride. I'm 210#, BTW). The advantage of the 940 is, it provides a lowered stance (about 1"), while retaining the travel of a standard 13" shock. Theoretically, this will limit the tendency to bottom-out (over the big bumps), it being easier to bottom-out a typical characteristic trade-off when you shorten the shock length/travel... Alan |
Originally Posted by AlanStansbery
(Post 9571916)
I put 940's on my 2010 SG thinking they would be better than the stock air shocks. I was wrong. They were really stiff. No matter how I adjusted them they were stiff. Even had the experts at Progressive at their Myrtle Beach tent try it. Still too darn stiff. I'm staying with Harley air shocks even tho you need to check the airpressure frequently.
Originally Posted by Gunnysgt
(Post 9572152)
Alan, how did you like the 940's with the lighter springs? Did you see a big difference?
I put 940's on my King and found that the bike handled way better than with the air shocks but the ride was too firm even with the preload set as light as it would go..... I sent them back for the lighter springs but Winter got in the way of trying them..... I also have a set of shorter air shocks reworked by Bitchin Baggers/Phoenix Customs that work sweet, but I am trying to eliminate the hassle of the air system...... Both the reworked air shocks and the 940's are way better than the POS stock Harley shocks....... http://img228.imageshack.us/img228/3021/20113j.jpg By hoofmender at 2011-04-12 |
i went form stock air shocks to the premium harley shocks to the progressive 440s and out of all of them the 440s work the best for me i weigh 210 there perfect. but i also ride solo.also i bought the 11 1/2 inch shocks.
Originally Posted by roadgliderick
(Post 9572213)
© 2024 MH Sub I, LLC dba Internet Brands
