power vision help
Old Mar 25, 2012 | 06:46 PM
rkoivisto's Avatar
rkoivisto
Default power vision help
I've got a PVision and I like the way the bike runs except for one thing. I get a single pop a lot of the time just when I let off the gas to shift.
Anyone know how to correct that?
Old Mar 25, 2012 | 06:54 PM
Northbound Southerner's Avatar
I get it too...I am going to call Jamie in the morning. Seems like my bike is running hotter than it should too...
Old Mar 25, 2012 | 07:05 PM
2black1s's Avatar
2black1s
I get the same pop you're describing. Not always, and I can't pinpoint any rhyme or reason to why it does it sometimes and not others except that it is most likely to occur on moderately aggressive upshifts between 3,000 and 4,000 rpm. I've played with the fuel settings in the 0 & 2 percent throttle positions trying to eliminate the pop to no avail. I've also disabled the autotune in the 2% throttle column (the standard settings already have the AT disabled in the 0% column). For the time being I've decided to live with it as it doesn't really bother me that much and the bike runs flawlessly otherwise. If you find a cure for yours, I'll be all ears.
My tuner is a PCV w/AutoTune, not a PV.
Old Mar 25, 2012 | 07:12 PM
57red's Avatar
57red
mine is running pretty warm and has decel pop too, need to do a few logging runs and see what they look like.
Old Mar 25, 2012 | 07:15 PM
kwo51's Avatar
kwo51
Whats the chance the baffle wrap is gone in your bikes? This is just a ??? Mine are and I know they pop a little.
Old Mar 25, 2012 | 07:18 PM
2black1s's Avatar
2black1s
Not mine. It has done it with three different sets of mufflers and the corresponding tunes.
Old Mar 25, 2012 | 07:29 PM
Rineharts do not have packing...
Old Mar 25, 2012 | 09:30 PM
Lonewolf176's Avatar
Lonewolf176
Look at the temp and then try increasing the corresponding cell in the de table.
blimblat
Sep 8, 2013 07:29 PM
Kentheworth
May 9, 2013 06:17 AM
jlasoftail
Oct 14, 2012 08:50 PM
datrahan62
Apr 20, 2009 12:08 PM
RODEO
Feb 15, 2009 11:26 PM
