Best satellite radio for your bike...
I elected to go with a Sportster 5 setup with multiple mounts since I am to cheap to pay for multiple subscriptions. I have a mount in both my cars, both bikes, and in the house. One subscription and only takes a minute to plug in. For the Ultra, I installed the mount in the rear Tour pak in the front left indent (corner). The antenna is also in the tourpak with no issues so far. To play nice with the HK radio I used the FM Direct adaptor (single wire) to the front that goes inline with the antenna. To use Sirius, simply use one of the preset channels on the radio (mine is #3 set to 89.9 FM). Volume works with hand controls. The unit has 20 preset stations (which is more than I will Ever use) and a small 2" remote that I velcroed near my controls should I need to channel surf. Rarely. Also, the power for the unit was already the the trunk via the standard power adapter (FLHTK). Simple, no weather issues, easy to move to other vehicles ($cheap$), no worries about theft since nothing is visible, and does not take much space. (approx 1"x4") Works for my cheap ***. Great for long range trips, and affordable. FYI, back when I ordered the radio they offered a Lifetime subscription for only 299 which has Long paid for itself since all of my vehicles use it. Good luck with your project.
I now use the one in my Zumo 665 - by far the cleanest install. However I did have a Sirius Starmate and used the following items:
On my EGC (I have fairing mounted mirrors like the SG), I used the
TechMount Harley Mirror Mount Part number 44020126
http://psndealer.com/dealersite/imag.../4402-0126.jpg
and for the antenna I used:
TechMount XM-AB Bracket Part Number 44020162
I just mounted the antenna bracket to the back of the mirror mount.
I also used the short antenna from tss
Yes the remote is wireless. Haven't had an issue but then again I don't change channels often. Just need my Howard Stern fix every once in a while traveling long range.
I also have the Zumo GPS but could not justify paying for another subscription. Works good for me.
Dave
Dave
I'll have to check out if the remote works through the tour pak when I get my Ultra Limited next week.
Thanks for your response.
I have a single subscription for the SIRIUS satellite radio. I use the Docking Stations and move it around.
I have one on my bike, in the car, garage, house and a home station with computer speakers so I can just plug
it in and have SIRIUS anywhere. I have the SIRIUS Docking Port installed on my right handlebar. This makes
it easy to change channels without taking my hands away from the handlebars, even with gloves.
I used the plate (76313-98) from Harley Hand Held CB Microphone kit (76312-98) to mount the
docking station on the handlebars. I then just taped the cigarette lighter inside the fairing for power.
I used the FM Direct adapter to get the sound in the radio. It plugs in the antenna input. This keeps
any local stations on the same frequency from interfering with the signal, but still listen to them.
The SIRIUS antenna is just magnetically mounted on top of the radio inside the fairing.
I have not had any problems with the signal. I made a nylon cover for anytime it rains.
If it starts and I am riding, I can stop and put it over the radio, or just reach up and take it off.
I have been caught in heavy rain before and have not had the SIRIUS damaged from rain.
