2010 FLHX erratic oil pressure
I have a 2010 streetglide and have been back to the dealership 3 times for erratic readings on the oil pressure guage. First visit the oil sending unit was replaced, 2nd visit they said thay found a loose ground and 3rd visit they once again replaced oil sending unit. Guage will be reading 32 or so cruising at a steady speed then make erratic quick jumps anywhere from 0-32 sometimes sitting at 0 for a few seconds and back to 32. Has anyone seen or heard of this problem? Any suggestions?
really seems that they should fix this on-going and consistant problem for good.
A loss of oil pressure will cause complete motor failure, which may result in injury or fatality if being operated.
A reliable gauge gives the operator ( any, not just the owner), notice of mechanical condition.
Use big words which allows the dealer to understand that this is a liability issue.
- and that you have records which show this is on-going and needs to be fixed, not just "parts replaced" hoping to solve the unknown problem.
Mike
Mike
OP= First visit the oil sending unit was replaced, 2nd visit they said thay found a loose ground and 3rd visit they once again replaced oil sending unit. Guage will be reading 32 or so cruising at a steady speed then make erratic quick jumps anywhere from 0-32 sometimes sitting at 0 for a few seconds and back to 32. Has anyone seen or heard of this problem? Any suggestions?
