HF wheel chock
Old Apr 10, 2012 | 07:57 PM
JHC210's Avatar
JHC210
Default HF wheel chock
I bought the Harbor Freight wheel chock. I plan on bolting it down but was wondering do I take the rubber floor mounts off the front so it lays flush with the floor or do I leave them on so it is up off the floor in the front?
Old Apr 10, 2012 | 07:59 PM
drukanfu's Avatar
drukanfu
Take dem off.
Old Apr 10, 2012 | 10:25 PM
LADNAR's Avatar
LADNAR
I left mine on...
Old Apr 10, 2012 | 10:28 PM
DHubbs's Avatar
DHubbs
I left mine on also. It bolts down at the rear only.
Old Apr 11, 2012 | 05:51 AM
CruzN's Avatar
CruzN
took mine off
Old Apr 11, 2012 | 06:24 AM
TUCCI's Avatar
TUCCI
I bolted mine with a bolt up front and one on the right side. It's on the 4th hole for the front adjustment. Even that far back it holds the bike fine and I don't hurt an already bad back.
Old Apr 25, 2012 | 07:45 PM
JHC210's Avatar
JHC210
Ok. Finally used the wheel chock. The front tire fit snugly in but it wasn't touching the bottom of the unit, maybe up about an inch or so. When I went to pull it off, she wouldn't come out. I needed help. Should the wheel be touching the bottom, do I have it too tight, do I need to start lifting weights? Couldnt believe how hard it was to pull it out without help. It's not mounted to the floor, yet.
Old Apr 25, 2012 | 08:01 PM
fishn4life's Avatar
fishn4life
I took the front bar off and I have the front pin in the #4 position (if the front pin location is #1)
16" tire
I couldn't get the bike off myself in position 1-3. Plenty stable in #4 position
[IMG][/IMG]
Old Apr 25, 2012 | 08:22 PM
sniperduce's Avatar
sniperduce
take em off
http://img840.imageshack.us/img840/8905/dscf1713q.th.jpg[/IMG][/URL]
Old Apr 25, 2012 | 10:58 PM
DHubbs's Avatar
DHubbs
Yea, its WAY too tight! Open it up till the tire touches the bottom! Shouldn't need a winch to get the bike off it. Mine works great! Yours will too when ya get it adjusted right.
