Another transmission bearing failure
Old 04-13-2012, 11:07 AM
Guntoter's Avatar
Guntoter
Guntoter is offline
Default Another transmission bearing failure
Our 2009 police Electra Glide had big chunks of metal on the drain plug magnet when I changed the trans oil a few weeks ago. Bike has 3,900 miles. I took it to the local dealer who tore into it and found the 3rd gear caged roller bearing gone, as in disintegrated. Of course now they are putting in all the bearings along with an output gear assembly as they had to heat the hell out of the big nut to get it loose and it tempered the output gear. Apparently the left mainshaft bearing, the one that supposedly goes all to hell on these 6 speeds, was OK but its obviously being replaced also.
Has anyone else had the small caged bearings go bad in the 6 speed? Those who have torn down the 6 speed before, do you also heat the large drive sprocket nut to remove it?
Old 04-13-2012, 12:29 PM
dgretz's Avatar
dgretz
dgretz is offline
Have had no problem with that bearing but have gone thru 3 mainshft bearings #8967 over the 95K miles so far on my "07"
Old 04-13-2012, 12:34 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
WOW...and just @ 3900 miles...that's gotta be a faulty bearing from supplier, or bike was assembled on Friday @ 4:59PM.
panz4ever
Shovelhead
06-19-2019 01:33 AM
V-Twins & Bowties
EVO
10-01-2017 06:05 AM
13RoadKing
02-04-2017 11:38 PM
prplglide
03-31-2013 09:15 AM
bigjohn1percenter
11-13-2009 07:05 PM
Quick Reply: Another transmission bearing failure
