Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   Accessory switch plug (https://www.hdforums.com/forum/touring-models/757428-accessory-switch-plug.html)
bthinnes 04-19-2012 08:12 PM
Originally Posted by Pagan48 (Post 9689866)
I'm under the impression the OP is looking to connect to the accessory switch on backside of fork opposite the aux light switch. Isn't that switch connected to the plug in the headlight nacelle? Maybe my wires are crossed
:icon_bricks:
Go to page 2-123 connector 67 is the connection of the switch to the harness. There is no tap at that location you would have to spice the wires. The switched open connector is actually connector 4 in Table B-1 labeled P&A Accessory. This is located under the seat and is a black female Deutch 4 connector.
https://www.hdforums.com/forum/touri...onnectors.html
This is another good post that shows the P&A plug (black) and the B+ (grey) plug located under the seat. what is not in this post is the California solinoid plugwhich is a bright Orange. Perhaps this is a RG rather than a RKC. or perhaps it had changed in 2012 model year.
TedMan 04-20-2012 11:55 AM
Thanks. Does anyone know if the B+ plug under the seat is fused? Thanks.
TedMan
lbkr22 04-20-2012 12:14 PM
Great info everyone. Thanks!
Harleypingman 04-20-2012 12:27 PM
TedMan
No, it's not fused.
TedMan 04-20-2012 12:42 PM
Re:
Originally Posted by Harleypingman (Post 9693905)
No, it's not fused.
Thx. TedMan
Weavr99FLHT 04-20-2012 12:43 PM
Mine acc. plug was jammed underneath the rear of the gas tank when bike was new and took some time to locate as it was completely hidden. Depending on the accessory, once plugged in, it may or may not be powered from the acc switch on the dash. Has to do with the config of the pins and which ones the accessory uses. I've plugged in accessories that are switched via ignition switch regardless of the position of the acc switch. and others that require the acc switch on. when looking at the plugs attached to the accessories, can see not all of the 4-pins are in use.
TedMan 04-20-2012 01:33 PM
Anyone know which of these individual part numbers I would need to make a male end to plug into the female deutsch connector under the seat?
http://www.harley-davidson.com/en_US...ts/-J01544.pdf
Thx.
TedMan
EricD10563 04-20-2012 01:34 PM
The switched Acc plug (Deutsch) on my 09 RK is under the seat and I have my fog lights wired to it, the switch on the Nacelle operates them. There is another power source under the seat I think it's called a B+ comnnector and it's a grey looking thing.
Harleypingman 04-20-2012 02:28 PM
Thx.
TedMan
Ted,
You'll need the parts id'ed as 1, 4, and 6 in the link you posted. You'll also need a crimp tool to attach the sockets to the wires.
No disrespect intended, but are you sure you want to undertake this since the pictures are pretty self-explanatory and the male and female connectors are pretty obvious, as well as the parts needed to make them.
In any case, good luck with your project.
Carl
TedMan 04-20-2012 03:04 PM
Originally Posted by Harleypingman (Post 9694331)
Ted,
Carl
No offense taken. Even if I muss it up, not an expensive mistake and good learning experience. I have a very good crimping tool already. Thx,
Ted
© 2024 MH Sub I, LLC dba Internet Brands
