Oil pan "Hex Plug"
Oil pan "Hex Plug"
I accidentally removed the oil pan "hex plug". I am on pain meds from a recent full knee replacement and I f'ed up. Nothing came out. When I looked it up in my shop manual it just shows it as Hex Plug on oil pan. The manual says do not remove but there are no torq instructions or guidelines if you do remove. I don't want to screw up my pan from my stupid mistake. I high temp loctighted it back in flush with the oil pan. Should I be worried?
Thanks for any advice. Feeling really stupid and pariniod I messed something up with just a damn hex plug.
Rob "Rogue Bear"
Ret. U.S. Army 18E
2012 Electra Glide Ultra Limited
Rob "Rogue Bear"
Ret. U.S. Army 18E
Received 69,951 Likes
Thanks guys. Feel better about it now. I read on some thread that you can crack your oil pan which sounds crazy but, I suppose you could if you just kept wrenching on it. I put it in tight and flush with the pan.
Thanks for the advice about not wrenching and being on pain pains I would heed that advice but my knee replacement was almost a year ago now. It is all F'ed up I wish I could be back to normal in 6-8 weeks. I have had severe trama to my knee in which the TKR is not working they even special made the knee just for me. I have another surgery in Jul/Aug and if that doesn't take I lose my leg from knee down. All they can do is keep my comfortable on pain meds and not riding my bike for the last year is not an option. I try to be careful but as you can see in ths thread the meds are turning my brains to mashed potatoes.
Thanks again for the advice and comic relief. @Greg you are probably one of those WO's that would wake me up saying commo is down and the batt. is dead....
And good luck with the knee.
Fly ace no, I know where that is. This is a hex plug with just an inset for a hex wrench no 5/8 bolt head. It's almost like a threaded freeze plug or something I am told it is where you would hook up an oil temp gauge. Was just nervous because manual said not to remove and had no instructions for replacement. I think the oter answers here put me on the correct path...
@Greg thanks man. Wonder if I knew your brother. Spent most of my time with 7th.
