different tires brands front and rear?
You can mix brands and radials & Bias ply with no problems...As a matter of fact some HD came from the factory with a radial and a bias... With the way they make bias cross ply today it has almost the same characteristics of a radial tire. This was told to me by a Guy that stayed at the Holiday Inn Express....
I have a Michelin Commander on the rear and a Dunlop Elite III on the front...
Just had to change the front and it is a Micheline Commander II and the rear is a E3, and before all that I had a 402 on the front and a E3 on the rear. they only seem to be the same on occasion. Once the back waers down probably after the wall run it will get a Commander II. then they will match again as long as I like the tire.
