Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   Pinging when it's hot (https://www.hdforums.com/forum/touring-models/768948-pinging-when-its-hot.html)
frenchbiker May 21, 2012 09:09 AM
My engine pings slightly when it's hot and when the oil temp reaches 220F, not under. My PC-V doesn't allow to add fuel by temp, only by rpm and throttle position. If I add fuel by rpm range, which I could, I'll be richer when I don't have to.
Am I the only one with this issue and how would you address it?
mkguitar May 21, 2012 09:14 AM
you have tried higher octane fuel ?
can you retard ignition timing ?
does it do it cruising, accelerating ?
what happens with-out the PCV ?
Mike
Gearhead3 May 21, 2012 09:14 AM
First of all, I'd try a different brand of gas. Sometimes a different brand will help with pinging issues. If you don't want to add fuel in the PC V table, you can always pull timing in the affected area of the map. Personally, I'd rather add fuel than pull timing. You'll lose some power pulling timing, not so much by adding fuel. Have you considered adding a oil cooler?
Airborne350G May 21, 2012 09:18 AM
Ditto on the gas. If I fill up using a gas station near work then I get pinging like crazy. But if I use one near home it runs good. I also try to use a pump that has a different hose for each grade of gas. Since I am only getting 5 gals I want it to all be high octane.
frenchbiker May 21, 2012 09:44 AM
I only use 93 gas so I don't think gas is the issue. I get a ping regardless what brand I use.
I have an oil cooler and 220F for the oil isn't that hot.
I will add 10% gas >2000rpm and >40% throttle and see what happens. It does it only when I accelerate, not when I cruise at a steady speed.
Thanks guys.
tourglider May 21, 2012 09:52 AM
Mine does the same thing. All the way down I10 from N'Oleans all the way back to home in Florida. Got gas from many different places and octanes. It cruises along fine but when I accelerate to pass it would ping away. I have a pc tuner also. Let me know how your changes work!
Airborne350G May 21, 2012 10:03 AM
I too only use 93 octane. Do you always purchase your gas from the same vendor? Sometimes it is as simple as bad gas.
frenchbiker May 21, 2012 10:15 AM
I purchase gas whenever I need on the road so it's not from the same vendor but it pings regardless of the brand.
If it was bad gas, the bike wouldn't run good when cruising. It runs fine, except for this slight ping at acceleration and ONLY when the engine is hot.
I'll add gas in the A/F mixture and see if it fixes the problem.
WARDSPARTSWERKS May 21, 2012 10:56 AM
Thanks guys.
At what point is this happening, is it possibly a "lugging" issue that can be corrected with a simple downshift.
gsxrmatt May 21, 2012 11:00 AM
Had this issue once before, filled up at diff gas station and no problems since.
© 2026 MH Sub I, LLC dba Internet Brands
