tire dot
Old May 23, 2012 | 11:09 AM
Scaredofrain's Avatar
Scaredofrain
Originally Posted by Roadking Cal
That actually applies only to the front tire/wheel.
The dot is a painted or inked addition to the tire, and therefore adds to the thickness of the tire in that particular spot. As the tire spins, that slightly raised portion of the tire creates added turbulence to the air stream. This added turbulence flows to the motor's air intake, and helps to make a better air-fuel mixture, therefore, improving engine performance.
I hope this clears up any confusion.
No, really....I looked it up on the internet!
Old May 23, 2012 | 05:33 PM
shorty07ultra's Avatar
shorty07ultra
Thanks again.
Old May 23, 2012 | 06:01 PM
t. sawyer's Avatar
t. sawyer
valve stem..line em up.
Kroozeabout.
Old May 23, 2012 | 06:04 PM
ynots's Avatar
ynots
dot lined up with the valve stem, although a lot tires are directional, the dot has nothing to do with it
Old May 23, 2012 | 06:07 PM
Taboo80's Avatar
Taboo80
There is no standard for the colored dot, you need to check with the tire manufacturer some put it on the heaviest point of the tire and others are on the lightest point. With that said before mounting you should determine the heaviest point on your rim with the valve installed and mount the heaviest point of the tire opposite the heaviest point of your rim. This aids with balancing. Look into Dyna Beads, most that try them swear by them.
Old May 23, 2012 | 06:08 PM
ynots's Avatar
ynots
Originally Posted by karbar99
"Dot to the intake side"
I'm lost on this one?
That makes about as much sense as putting it on the East side of the motorcycle
Old May 23, 2012 | 06:16 PM
karbar99's Avatar
karbar99
"No, really....I looked it up on the Internet"
So what "did" the Internet say??
djbiker
Wheels/Tires
Jan 27, 2023 08:11 AM
Ultra Pearl
Jul 23, 2013 09:31 PM
albngore
Jan 8, 2011 02:26 PM
FotoDeville
Jun 8, 2010 08:09 PM
HDF Tech
Jun 25, 2005 11:32 AM
