SG lowers w/ aux lights ???
Old Jun 3, 2012 | 04:32 PM
bgdv1's Avatar
bgdv1
Default SG lowers w/ aux lights ???
any one running lowers on their SG with aux lights. i heard they may not clear the turn sigs. i thinking of lowers and need to see some pics before dropping $$$ on lowers.
Old Jun 3, 2012 | 04:53 PM
CHILLLS's Avatar
CHILLLS
i had no issues with mine but i dont have the regular driving lights so this probably wont help.
Old Jun 3, 2012 | 05:04 PM
springer 03's Avatar
springer 03
I purchased a set of the old style lowers and the turn signals would hit on full turns. The only time it came into play was when I was maneuvering with my feet. I don't see how driving lights could be an issue as the ultras have both.
Old Jun 3, 2012 | 05:12 PM
Harleypingman's Avatar
Harleypingman
If you're referring to the Custom Auxillary Light kit that uses the SG tear drop turn signals and passing lamps using a separate bracket on each side, there's no problem using it on your SG--it's the same bracket/turn signal/turn signal rig that the CVO Ultras (that have vented lowers) have been using since '06.
I had them on my '04 EG and they fit w/o issues.
Check HD's fitment information in the paper catalog or on-line at HD's website.
Carl
PS: CHILLS, you need to change the way you posted pictures so they'll show top to bottom, not side to side--scrolling top to bottom is easier than side to side.
bgdv1's Avatar
bgdv1
its the way and style of the SG mounts vs the EG mounts
Old Jun 3, 2012 | 05:20 PM
CHILLLS's Avatar
CHILLLS
ohhh... how do i do that? sorry
Old Jun 3, 2012 | 05:35 PM
Harleypingman
I just use the insert picture feature, add a url for the picture from the host site (in my case photobucket), then hit the space/enter bar to go down two spaces and repeat the picture insertion process.
I don't know how you post multiple pictures horizontally.
Carl
Old Jun 3, 2012 | 05:44 PM
Harleypingman
The SG and EG use exactly the same mounting points for the turn signals on your SG and the turn/signal bracket the EG uses--two screws per side. The Ultra CVO's use the same mounting points with a different bracket that accepts the SG turn signals and EG passing lamps--it's the same exact bracket sold by HD as the Custom Aux kit for SG's and EG's who want to get rid of the towel bar rack on a non-CVO EG.
I'm not going to argue w/ you; particularly if you won't take the time to consult HD's website or their paper catalog. Perhaps someone will post a picture.
Carl
Old Jun 3, 2012 | 06:03 PM
DuraGlide's Avatar
DuraGlide
SG style brackets and turn signals on my Ultra with no issues
Old Jun 3, 2012 | 06:10 PM
DuraGlide's Avatar
DuraGlide
My SG with aux lamps, SG turn signals and lowers with no issues
