stripped torx bolts on clutch cover
Old 06-19-2012, 05:48 PM
deepsea's Avatar
deepsea
deepsea is offline
Default stripped torx bolts on clutch cover
Several of the bolts holding clutch inspection cover on are stripped. What is the best size drill bit to use to cut the heads off so I can replace them with allen head bolts?
Old 06-19-2012, 06:00 PM
deepsea's Avatar
deepsea
deepsea is offline
I forgot to say its an 07 road king
Old 06-19-2012, 06:01 PM
Airborne350G's Avatar
Airborne350G
Airborne350G is offline
Use an impact screw driver and a larger torx bit
http://www.harborfreight.com/impact-...ase-37530.html
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I think those are 1/4-20's.The major dia. would be about .250".
I would work my way up to a 1/4".
Old 06-19-2012, 06:03 PM
Airborne350G
Forgot to add that some have drilled off just the heads and then used vice grips in them after the cover was off.
Old 06-19-2012, 06:14 PM
kredin's Avatar
kredin
kredin is offline
Yep, I did the same thing. Then I went to Lowes and replaced them with Allen head screws.
Old 06-19-2012, 06:41 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
It pays to use the correct sized Torx. This is a common mistake people make. Use one size too small, strip out the heads, and there you go.
Old 06-19-2012, 07:11 PM
senna's Avatar
senna
senna is offline
Do not drill the bolt to 1/4",that is the outside diamiter of the bolt. For 1/4" tap, the drill size is 13/64, 1/64 over 3/16.
When you say clutch inspection cover, are you referring to the cover on the left with 5 torx head bolts?
I would ( very carefully) use a center punch on the outside diameter of the head of the bolt and drive the bolt loose.
BTW, I'm not sure those bolts are even 1/4".
Old 06-20-2012, 04:27 AM
SteelCityRider's Avatar
SteelCityRider
SteelCityRider is offline
I used easy outs and drilled them out and bought new ones to put in.
Old 06-20-2012, 05:07 AM
glide2005's Avatar
glide2005
glide2005 is offline
Over the years that I've worked on my bikes, I've used torx-plus wrenches and have not had a problem with striped heads. Also apply a lot of pressure inward on the bolt when tring to brake it loose.
Quick Reply: stripped torx bolts on clutch cover
