2008 Fuel Pump Install Help
Old Jun 22, 2012 | 11:17 AM
rgardjr's Avatar
rgardjr
Default 2008 Fuel Pump Install Help
I've got a friend that is swapping a stretched tank on to his 2008 Street Glide. He doesn't remember where these two ground wires are suppose to go. Can anyone help?
Old Jun 22, 2012 | 11:28 AM
mkguitar's Avatar
mkguitar
I have a wiring diagram here- what color are those wires under the black sheath ?
sure they are grounds ?
the fuel filter shell gets one ground, the "top plate" gets another
mike
Old Jun 22, 2012 | 12:26 PM
bgreen4's Avatar
bgreen4
Stage IV
The wire appears to be silver. Would you be able to post a copy of the diagram? Thank you!
Old Jun 22, 2012 | 12:47 PM
mkguitar's Avatar
mkguitar
here's what i can tell you from the 09 service manual/diagram
black is ground ( this is the "dirty ground" as described in the manual)
goes from pin D of the connector to the top plate, then to the fuel filter shell
Blk/Grn from Pin C to top plate ( fuel level?) ( this is the "clean ground")
orange/gry from pin B to fuel pump ( this carries power from the fuel pump fuse)
Yel/wht from pin A to float ( this goes to fuel gauge)
again this is the 09 stuff- so if the colors are different we gotta find an 08 book, which I don't have
bigger, better picture ?
mike
Andy from Sandy
Jul 26, 2019 02:39 PM
lowflyer
Electrical/Lighting/Alarm
Apr 25, 2015 08:46 AM
wborden
May 6, 2014 01:59 AM
rdondes
May 18, 2013 02:52 PM
Bartman1959
Jun 22, 2012 07:12 PM
