Question about HD Tour-Pak Brake Light/Running Light/Turn Signal Conversion Kit Part#
The HD website states this conversion kit, #69200042A, is for 97-later Ultra models with the Ultra Tour-Pak. I would like to convert the run/brake lights on a 94 Ultra Tour-Pak to run/brake/turn signal lights and don’t understand why this kit is not compatible with the 94 Ultra Tour-Pak. Does anyone know why this kit can’t be used on my 94 tour-pak? Is the wiring in the main wiring harness for the rear lights the same for the 94 as the 97-later Ultra’s? I don’t have a wiring diagram for both years to be able to compare them. Any help on this would be very appreciated.
Here's a write-up w/ pictures I did when I installed the HD kit. You can compare pictures of what my bike had to what's on your bike, which may provide some help:
https://www.hdforums.com/forum/touri...rsion-kit.html
Also, you can compare p/n's for the '94 and '97 using Ronnie's HD website--just go to check-out and you'll get HD p/n's.
Good luck.
Carl
Good luck.
Carl
I have just fitted a tour pak to my 1995 Roadking. I believe the reason you cant use the wiring kit is because pre 1997 bikes didnt have the relevant wiring/plug already there. I have spliced in to the rear lighting/brake light wiring and fitted a quick detach socket and altered the plug on the tour pak end as well. I have the socket under the seat, so just need to remove the seat when fitting and removing the tour pak.
BlackPearl#1
04-17-2013 09:07 PM
glide2meetu
06-19-2011 09:05 PM
