oil leak at oil pan
oil leak at oil pan
I just noticed an oil laek from my 2010 Ultra looks like its comoning around the oil pan. I called the stealership to set up an apointment in two weeks. My question is do oil pans leak or should I just replace the oil ring on the drain plug first? I have never had a Harley that has had an oil pan leak. I would hate to take it in for somthing minor
check this thread on oil leak from muffler bracket bolt at transmission
https://www.hdforums.com/forum/touri...ger-bolts.html
Hey Guys
Thanks for the help you nailed it. The exaust hanger bolts are gone and there is evidence of a leak. I called the dealer and they know about the service bulletin. This is a great forum, most of you guys are very helpful and the knowledge base is outstanding. I guess one thing about Harley riders are they tend to loyal to their product line so there is many years of experience.
Great work
Great work
Hi Guys
I got the new torque specs for the trans and oil pan bolts. 122 in lbs for the small bolts and 22 ft lbs for the big bolts. BTW what was Harley thinking by connecting the exhaust bracket to that housing? Does it mean that they drill all the way through to a open hole. Seems kind off lame too me.
