looking for tail light wiring schematic for Canadian 2012 Street Glide
Does anyone have a wiring diagram for the tail light assembly that is put on the Canadian 2012 Street Glide. Our government would not approve the fender skirt tri-light, so we have a fender mounted brake light and turn signals. Want to add Custom Dynamics plasma rods to fender inserts but need to have wiring info.
Thanks in advance
Thanks in advance
blue is run light --- wire to this, you can tap in at the fender or under the seat before the wiring goes under fender- which ever is easiest.
black is ground
red is brake
complete wiring diagram for dom and int'l models is in the factory service manual
or you can wire into the ACC plug under the seat.
Custom Dynamics has a good rep for customer service, if you have questions, ask them they will likely know the answer
mike
black is ground
red is brake
mike
