Punch 400 4 channel. Stock HD head unit, Moved ground to triple tree, Radio Bolts and to ground wire off headlight aux where im getting power as well all (3) same issues.
PBR400X4D: Blue light for power goes off with ignition however remote wire stays hot. I have the bike completely apart for new fat tire kit. i suspect a tumbler is off in ignition.
Ok a couple things should fix you up. First and foremost move your ground to the battery or the ground post in front of the battery. Secondly you do not need the remote wire. The amp has an auto on feature that turns it on when it senses a signal from the HU.
