True Dual Exhaust for 2011 Road Glide Custom
I am looking at changing from original stock dual exhaust pipes and need suggestions. I want to keep the dual look but looking for more deeper sound and have looked at Vance and Hines, Bassanti and Samson brands. Are there drawbacks to true duals instead of two in one? Any suggestions?
Thank you,
2BTRU
Thank you,
2BTRU
email MGS customs, they have a killer deal going on some slightly blemed true duals.
Thank you,
2BTRU
Thank you,
2BTRU
Check out Cobra Power Port Duals. It's a TD head pipe with a "power port" that runs between the two pipes designed to equalize the sound pulses. Combined with my CFRs, the exhaust sounds amazing. Any slip-on will work, including Cobra's, but, just thought I'd throw them in the mix...
You can hear sound clips using the link in my sig...
Good luck!
E
Good luck!
E
Let us know when you are looking around for pricing, we get great deals on all three brands you are referencing below. Shoot me a PM if you are looking for more information, but I believe you need 5 posts to accept/send personal messages - welcome from WanaRyd!
Thank you,
2BTRU
Thank you,
2BTRU
Thank you,
2BTRU
Thank you,
2BTRU
True duals sound best to a lot of folks but they don't really offer a major power (torque) improvement beyond better exhaust flow.
Duals with a crossover (or connection between the two pipes) can often make a bit more improvement to power (torque) due to improved scavenging effect. They aren't "true" duals but spent gasses are better timed and somewhat controlled to let one pipe help "suck" exhaust out of the other and they sound damn near the same as true duals do.
2 into 1 most often offers the best power (torque) improvement because exhaust gasses are even more well controlled and scavenging is damn good. However, you have to like the related sound too so...
All will reduce heat (no CAT converter).
The only drawback I heard of is you lose a little low end torque as compared to a 2:1 system or duals with a crossover that helps pull air from the other cylinder.
I like the look of duals, and had Reinhardt's on my 04 FLHRSI, I am going to probably go with black ones this time but same pipes.
I love the tone of them and they are quality, not to concerned with the small lack in torque although if you load your bike and have a passenger and are going to a stage 2 say for more power then you might want to squeeze every last drop out for low end torque you might want to consider 2:1 or duals.
Anyway I like the duals.
Lump
Lump
MGS True Duals
Lump
Lump
