Download???
Old Oct 24, 2012 | 06:13 AM
Keithhu's Avatar
Keithhu
Originally Posted by Guitardude
Adding pipes and more air equals bike even leaner than it was from the factory, and you can cause some top end engine damage..
False. Proof?
Old Oct 24, 2012 | 07:15 AM
billnourse's Avatar
billnourse
Originally Posted by Keithhu
False. Proof?
If you increase air flow with free flowing exhaust and free flowing intake, You are going to go lean unless you add fuel. That is just a fact of life.
I had pipes and intake and depended on the factory ECM to adjust fuel enough. It did not, based on the increased engine heat, detonation and engine going into heat management mode on occasion.
Whether or not there was enough increased heat to cause valve or piston top damage or burn plugs I don't know, but it was certainly enough to making riding uncomfortable.
Power Commander V added fuel, and the heat went down, pinging stopped and bike is much smoother. Don't know if that is proof or not, but I'm convienced that it was 300.00 well spent.
Bill
Old Oct 24, 2012 | 07:16 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by Heo
I just purchased 4" Rinehart slip ons and SE Extreme Billet Air Cleaner Kit for my 2012 Street Glide.
Is it necessary to have a download done?
As you can see, the answers are pretty much all over the floor.
There's a HUGE difference between a fuel management system and tuning system. Most fuel mgt systems do nothing to address any changes in VE's, enleanments, enrichments, timing, temp corrections, and EGR tables to name a few.
Hey, it's your bike and only you can determine how well you want it to perform or last even in a completely (or nearly so) stock configuration.
Old Oct 24, 2012 | 09:55 AM
Uncle Larry's Avatar
Uncle Larry
Hey "Heo" ... as stated earlier, there are more "Expert Opinions" ( mine included ) on this subject than you can shake a stick at ... However, I would guess that before you're through "modding" your new scooter you'll probably do something else that will affect it's tune ... You've got a $20,000.00 scooter, don't cut a corner on getting your AFR ( Air Fuel Ratio number ) where it should be ... The HD Download is a "compromise" between the stock settings ( which can be adjusted minimally through the ECM by means of voltage readings from the O2 Sensors ) and "almost" perfect ratios when tuned by a competent tuner who uses an EGA ( Exhaust Gas Analyzer ) . I have an 09 FLHTCU which had the HD Download ( @ $150.00 ) and wish that I would have spent the extra dollars for a ( my choice now ) Power Commander V in the beginning ... Hope this helps ... Good Luck Brother!
Old Oct 24, 2012 | 06:40 PM
Heo's Avatar
Heo
Thumbs up
After doing some research and taking some advice from UNCLE LARRY and others, I have decided to go with the Power Commander V.
I bought it today from FuelMoto...great service!!!
Thanks everyone!
trappermarc
Mar 8, 2018 02:56 PM
captainron62
May 31, 2012 08:16 AM
SoCal Ultra
Exhaust System Topics
Jun 22, 2008 08:35 PM
wolverine66
May 3, 2008 09:36 AM
hennyk
Dec 31, 2007 06:33 AM
