stock 2 into 1 catless horsepower
Just curious if anyone is making decent horsepower with a stock style 2 into 1 with no cat, putting a 103 inch kit together and the guy insist on running the 2 into 1 off his street glide, also, does anyone know what type of thread the 2010 and up oxygen sensors have, I need to block them off. Thanks chad
Decatted dyno run
If you search around on this Forum, you can find a Fuel Moto post where they dyno'd a stock 103 w/ decatted stock header w/ their slip ons and air filter vs. their 2-1-2 header w/ the same slip ons and airfilter. Gained about 2 hp (~87 vs. 85) and 3 ft. lbs. of torque(~94 vs. 97). Both curves were almost identical. Don't know about you, but I don't think I can feel that difference in the saddle. Unless and until I change cams, I'm going with a decatted stock header. My 2 cents-no charge!
Only 2-3 hp gain is what I've seen as well. The o2 sensor plug size is 12mm.
http://www.cruisercustomizing.com/o2...art/BC-40-0296
A stock "style", or an actual OEM 2:1 from a 2010 SG/RG. I'm making decent power with the OEM 2:1 on my 88", but I wouldn't use it on a 103".
Amazing, out of 6 replies only 1 person actually read your post well enough to try to answer your question. I can't help you with an answer, but I'm interested in some info also since I've thought about trying that setup with a good muffler. I just get a kick out of all the replies to posts that are made by people who don't read the whole post & don't answer the question asked.
I did the catless header on my CVO SG. I did it mainly to cool it down. It helped a lot and sounds much much better.
If you after power you need to think about Cams. with the other things you want. It is a small price with a big refund in power.
I did my cams on my Ultra when it was time to check the cam tensioners. Saved some bucks that way.
What you will get without the cam change will be a cooler running engine and better throttle response. a few more ponies but you will notice a difference. Better sound, may want to hold off on the mufflers and do the catless headers first. You might get the sound you want. I did.
