Service manual torque value....THIS CAN'T BE RIGHT
Long story short I putting a wrinkle black cover on the engine of my 2012 Street Glide. The service manual list 144-156 in-lbs for the primary cover...I'm thinking man that can't be right.
So I check the manual for my 2010 Dyna and it lists 108-120 in-lbs. They are basically the same covers and bolts...so what gives? Can anyone check the values for other year model touring bikes and tell me what it list? Thanks |
I'm not in front of my shop manual, but 120 inch lbs will work just fine
This might be stating the obvious, but I would like to reiterate the fact that the value is in
inches-lbs, NOT foot-lbs. That sounds about right. |
Which is basically more or less past snug with an allen wrench....
Originally Posted by Cornel
(Post 10550761)
inches-lbs, NOT foot-lbs. That sounds about right. But 108-120 in-lbs compared to 144-156 in-lbs is a pretty significant difference. I would say enough to at least strip out the heads if not break the bolt all together. I mean the bolts are the same on both bikes. I'm thinking 110 in lbs should be plenty. |
Why did ya buy a service manual or look in it if ya ain't gonna follow it? I'm sure it will work either way, but maybe there is a reason the values changed.
Originally Posted by 0ldhippie
(Post 10550913)
How do I know that you ask...because I have the service manuals and look at them while I'm working on my bikes. I question what's in the manual for the 2012 touring bikes beacuse I don't want to strip out a bolt head or threads. Good enough for ya? |
I just checked the 2011Touring manual and its listed as 108-120 in lbs. Follow your manual is the best I can tell you.
Quit second guessin it and torgue it on! Done..... Geesh quit over thinking it....
Identify the thread size, then check a "generic" torque chart, if it isn't higher than that, it should be ok. My 06 calls for 84-108 in/lb, so there is obviously something different among the models/years.
| All times are GMT -5. The time now is 03:23 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
