Should Have Stayed in Bed Today
Old Jan 20, 2013 | 06:51 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Should Have Stayed in Bed Today
Installed my MGS duals and now I can't get the bike started. Plenty of gas but it appears no spark. Bikes not throwing any codes. I'm running a Rev Performance EMS which had the bike running fine after I installed new lifters and adjusted the push rods about a month ago. Bikes been sitting ever since. I thought maybe lifter bleed down but with the plugs out and finger over the hole, crank it and the compression blows your finger back. Rev Per controller LED's blink and then go solid like always. I checked every electrical connector on the bike and their all tight. Fuses all look good.
I did wash it today but only from the cylinders down. Used my MC air dryer like I always do.
Did I miss anything??????????????????????
I know, the new springs on the Hayden Tensioner I installed while doing the lifters must be causing it not to start.....LOL...
Old Jan 20, 2013 | 07:11 PM
03dragonRK's Avatar
03dragonRK
Kill switch?
Old Jan 20, 2013 | 07:21 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by 03dragonRK
Kill switch?
Worked fine a month ago and no water got even close to it.....But anythings possible at this point.
Old Jan 20, 2013 | 07:24 PM
Bagger71's Avatar
Bagger71
Alarm Fob near?
Old Jan 20, 2013 | 07:29 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by Bagger71
Alarm Fob near?
Yes, but I'm wondering about the battery strength. Going to get a new battery tomorrow. Can it be that easy!!!!!!!
Old Jan 20, 2013 | 07:35 PM
Iceman24's Avatar
Iceman24
FOB battery would be easy fix & hopefully the gremlin, in your case. Did you pull any fuses during your exhaust install? How about disconnecting your EMS & seeing if the bike fires w/o the box? Wouldn't rule anything out, at this point.
Old Jan 20, 2013 | 08:03 PM
btsom's Avatar
btsom
If it turns out to be the fob battery, that is a strong indicator you need to review how to establish and then enter the manual code to get you going again without the fob, beats calling for a tow truck.
Old Jan 20, 2013 | 08:06 PM
stupid_rope's Avatar
stupid_rope
i keep a spare fob battery in my bag. my bike will occasionally act like the fob isnt near when its in my pocket. i put a fresh battery in every 4-6 months
Old Jan 20, 2013 | 08:10 PM
jmacdonald5's Avatar
jmacdonald5
..I know..I know...but I'll ask anyway....Gas?
Old Jan 20, 2013 | 08:45 PM
mikelikesbikes's Avatar
mikelikesbikes
OP said he had gas in second sentence.
Someone else asked about the kill switch and you replied anything is possible (I believe). Have to ask, is it in the ON position???
