What model years have interchangeable exhaust fitment?
There is a sweet deal on a 2 into 1 exhaust system for sale in the touring parts. Problem is it is from a newer bike. I have seen exhaust systems advertised for fitment on 96-2012 and of coarse seperatly for 96-07, and 2008 and newer. I have heard that the ports on a 96 are both a different size and angled differently than a 88. Can anyone tell me if this is true?
Thanks Mr. Brown.
I am starting to think the multi fit models are because they come with both the 12mm o2 bungs, wheras the models specific to 96-09 have ONLY 18mm bungs, and 10-later have 12mm bungs. Now I am hearing the exhaust ports on all models are the same angle and location across all years.
I've often wondered this same thing. I have an extra set of V&H Big radius 2:2 for my '09 I've been wanting to sell, but I have no idea what other year models they fit on. It seems I've heard of some exausts that fit on 09's and 09's only. I guess I should just call V&H, if anyone knows it's got to be them.
generally header pipes "should" fit for 1984.5 to 2008 models.
in 2009 the frame changed- and is wider at the rear- some aftermarket headers may fit- stock configuration headers will not fit the 2009+ frame.
2009+ header may fit earlier frame models with spacers on the mounts- and some fiddling- but not a direct bolt on
once physical fit is determined, o2 sensors ( or not) are a consideration.
the pre/post 1995 muffler fitment issue is due to a change in header pipe flange at the muffler
mike
mike
mike
mike
Hey guys, I know its a bit off from the original topic here but I found a 2-1 exhaust for a 2017 Softail... I have a 2008 xl1200n, now I know they're completely different bikes but it's such a sweet deal, it hard to pass up.. so I guess what I'm asking is how different are these two bikes exhaust set ups? I can Tig welding and whatnots to modify if needed but is it worth it or would a guy even be able to make this work?
mike
mike
Brary
