Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   can't trust my thermometer (https://www.hdforums.com/forum/touring-models/859238-cant-trust-my-thermometer.html)
starrider60 Mar 29, 2013 06:27 PM
Ambient air temp on my 2005 ultra always shows 10 degrees or more than the real temp. What gives?
rleggs Mar 29, 2013 06:31 PM
It's a POS!
pswomack Mar 29, 2013 06:33 PM
Umm could it be because of the heat from the front cylinder, the temp sensor is mounted on the left side of the neck and as we all know, heat rises!
WAYJO Mar 29, 2013 06:42 PM
Like rleggs so correctly quoted, it is basically a useless, inaccurate space waster in our fairings. Take it out and install a oil temp gauge that will give you some info that is important to your bikes operation.
Lowcountry Joe Mar 29, 2013 06:44 PM
They make the air temp gauge so shitty that it forces you to remove it and replace it with an oil temperature gauge. It's an absolutely worthless thing to have on a motorcycle.
Drat Mar 29, 2013 06:44 PM
Welcome to the world of useless toys!! If you do a search function you will discover that a lot of people have removed the thermometer and have installed other gauges in that spot. I left mine there as I am entertained by how much it is off compared to outdoor ones that I pass by during my travels. So, relax, we all have experienced it if our bike came with one.
dan conner Mar 29, 2013 07:39 PM
that's normal.
starrider60 Mar 29, 2013 08:32 PM
Thanks for the insight. I knew i'd get the scoop. Whatta great bunch!
skratch Mar 29, 2013 10:01 PM
just ignore it. you don't need a gauge to tell you it is either hot or cold.....
yzergod Mar 29, 2013 10:17 PM
I ran the sensor for mine to the frame as close to the front cylinder so I could keep an eye on the temperature my nuts are cooking at! :)
© 2026 MH Sub I, LLC dba Internet Brands
