Progressive Monotubes
Old May 11, 2013 | 04:19 PM
Flying Horse's Avatar
Flying Horse
Default Progressive Monotubes
Just installed the Monotubes on my RK Custom and went for a 90 mile jaunt with the wife.
My opinion; If you have a stock Harley Touring bike then you need to add these. The difference is impressive. The front wheel rolls over bumps instead of slamming them. It is stiffer in the turns thus having more control. Really happy with this upgrade. The 944's are next.
Try it, you'll like it.
Old May 11, 2013 | 05:23 PM
2ropes's Avatar
2ropes
Did the same myself and plan on ordering the 944's on my next cc cycle!
Old May 11, 2013 | 05:24 PM
FL-kruzen's Avatar
FL-kruzen
Does it stop the "clank" if you drop off a bump?
Old May 11, 2013 | 05:27 PM
MyFirstHD's Avatar
MyFirstHD
I put the 444's on back, and like them so much that I'm looking for the monotubes next. FYI, Progressive said the 944 drop the bike so if you don't have a problem with seat height go with the 444.
Old May 11, 2013 | 08:41 PM
seltzer's Avatar
seltzer
Did the monotbes first, then 444s. The monotubes made a huge difference. Only around the block on 444s.
Old May 11, 2013 | 08:56 PM
slickrick_58's Avatar
slickrick_58
Had the 444HDs on the back (FLHRSI shock length is 12") and the monotubes on the front for 2 years now. I was amazed at how different the bike rode and handled. It is so much better, I took the touring link off. Of course I do have the Glide Pro swing arm bushings and motor mount on.
Old May 11, 2013 | 10:20 PM
Groucho1's Avatar
Groucho1
I put the monotubes in a few hundred miles ago...I still have the clunk.
Old May 12, 2013 | 05:58 PM
Flying Horse
No clank so far.
Old May 12, 2013 | 07:31 PM
tencrore's Avatar
tencrore
I've been thinking about Monotubes. How difficult are they to install? Thanks in advance for your help.
Old May 12, 2013 | 08:15 PM
Fat Mike's Avatar
Fat Mike
Yes, I'd like to know this too... Was going to change the fork oil here soon. Is it pretty much the same procedure? Drain the oil, but just take the stock springs out the top and replace the oil? Or is there a whole lot more involved? I see where to buy the Monotubes, but no installation instructions. I have a service manual but i'm not sure if that will be the same instructions on installing them.
