Rear pulley choices?
ok I have a 98 RG
Im doing a swingarm conversion and have a newer rear wheel....
has the 2.2" hole opening for the wheel
Is there any pulleys i can get with the 1 1/2" belt 70T with the hole opening? as my stock has a hole less than 2"
or am i going to have to get newer pulleys with a smaller belt?
what part numbers to look for? both pulley and belt
That sounds right, as the ball-race bearings were introduced around then. Check the wheel bearings installed. Earlier tapered roller wheels have a separate bearing seal each side, but the seal is integral with the bearing for ball races.
When I replaced my belt at 119,000 I thought it best to replace the rear pulley too. It took a couple of days but I got an almost new one on EBay for $65 delivered. Just look out for them, and you may have to EMail the Sellers to confirm the hole size (2.25") as they don't often list that.
