Trick to removing an 07 Oil Pan?
Does anyone know if theres a trick to sliding the oil pan out the back? I got frustrated and walked away for today but its hanging up on the baffle springs and hitting the tire, from what I have read you dont need to remove the wheel but Im having a difficult time with the baffle. Any suggestions or ideas would be greatly appreciated.
I dicked around with it for a spell and got frustrated working in the heat and at first walked away after trying to do it w/o removing the rear wheel or undoing the front motor mount.
So the best description I can give is to unbolt the front motor mount, pull the rear axle, unbolt the lower shock bolts and lift the wheel up into the fender, jack up the motor up to the frame (about 1/2"). It slips in and out like a dream, my x mamber had a bow in it from using a jack but using the above method it wasnt an issue. While out I bent the x member back to straight. It sure made it easy using a table lift. Hope this method works for others.
dsteele485
07-23-2006 01:07 PM
