Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   It's baaaaack! Primary chatter. (https://www.hdforums.com/forum/touring-models/894287-its-baaaaack-primary-chatter.html)
RoadHog659 Jul 26, 2013 07:24 PM
Thought I had it figured out when I had the SE compensator installed and then tightened up the footboard bracket that my Indy forgot to snug up. Also dumped exactly 38 oz. of Formula+ in the primary. But the chatter is back! I can't find anything else loose to tighten. Very frustrating. What else could be causing a progressively louder chatter between 2000 - 2500 rpm while shifting up thru the gears? It can't be "normal" because it didn't make that noise for the first 25,000 miles. What do bad lifters sound like?
big block Jul 26, 2013 08:23 PM
Add another 16 oz of oil to your primary. Damn the specs!
RyanC Jul 26, 2013 08:55 PM
I am no expert but you may have a bearing issue in your primary. I have a buddy that had a similiar description to your issue. He let his fester till the bike was almost unrideable. Primary bearing was the cause. Set him back almost $800. Good luck
RyanC Jul 26, 2013 09:01 PM
BTW, US Navy active Duty but your state is my home of record. OH...
RoadHog659 Jul 26, 2013 09:20 PM
Thanks for your service, and thanks for the response. Hadn't thought about bearings.
TUCCI Jul 26, 2013 09:59 PM
I have what your describing but it only happens after it's shut off for a bit then start it up again. Its more pronounced between shifts then after a few miles stops. From what I've been reading it may be either cam chain noise of lifter bleed down. I had the dealership look at it and it wasn't doing it at the time. It almost sounds like the top end isn't getting lubrication till the system pumps up again...hell I don't know. As far as thinking it's the compensator, I would stop thinking it's the problem.
TUCCI Jul 26, 2013 10:01 PM
Right.......
RyanC Jul 26, 2013 10:23 PM
Easy day... Amost done. 17.5 years in the Submarine force. hope u find your problem, fix your bike and rest your mind/
Loc_Tite Jul 26, 2013 10:24 PM
If it's the inner primary bearing you would be able to hear it at idle with the bike not moving. Pull the clutch lever in, shift into first, then back to neutral and keep the clutch lever pulled in - should be quiet. Then release the clutch lever and listen for it to sing. If it does I'd bet inner primary bearing
user_1534GD Jul 27, 2013 01:53 AM
One would think/hope that whoever changed the comp also checked the 'primary mechanics'... IPB, drive chain, tensioner, clutch/spring/hub bearing, MB, both door bearings, shaft...
What mods have you done to this bike... Has it been on a dyno...
© 2026 MH Sub I, LLC dba Internet Brands
