How do I get these aligned
Old Jul 30, 2013 | 06:31 PM
bandit5001's Avatar
bandit5001
Default How do I get these aligned
Ok I got some 4" bags from a member on this Forum and put them on the right side looks fine but the left is super close to my pipes how do get this to match the right side
Old Jul 30, 2013 | 06:33 PM
bandit5001's Avatar
bandit5001
Couldn't get both pics to upload for some reason
Old Jul 30, 2013 | 06:39 PM
MAJOR's Avatar
MAJOR
Sorry to see it doesn't line up well. Can you modify the exhaust bracket enough to move the muffler over closer to the fender?
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
I bet you have the vance and hines true duals, don't you? if you do, they won't get any better than than, unless you start bending pipe, or really put pressure on the headpipe to get it centered, and risk breaking the pipe or pulling the studs out of the head. thats just the way the true duals are
Old Jul 30, 2013 | 06:41 PM
hardheaded's Avatar
hardheaded
looks like it's the right side that don't line up to me. are they after market bags?
Old Jul 30, 2013 | 06:57 PM
bandit5001's Avatar
bandit5001
Ok so shouldn't expect any better than that with Vance and Hines pipes, thanks guys
Old Jul 30, 2013 | 08:00 PM
harleycharlie1992
how did I know!?
Old Jul 30, 2013 | 08:11 PM
RollaMo's Avatar
RollaMo
Looks to me like it's the bags that aren't lined up right.
Look close at the spacing between the bag and rear fascia.
The right side bag has a wider gap at the bottom, and the left side bag is pretty even all the way down.
I don't think it's the pipes.
Old Jul 30, 2013 | 08:38 PM
harleycharlie1992
the bags are a bit off, but the V&H pipes bring the exhaust out at a slight angle, not noticeable untill you try to center the mufflers in the cutouts. I've installed about8 or 9 sets and every one angles it outward. I've tried making different brackets in the rear, but stressed the pipes so there was a harsh vibration, played with the center mounts, even tried heating my own set and put a bend in them but that just caused the heat shield to vibrate, its just the nature of the beast. If you look at the stock mufflers on a cvo, the tabs, are welded in a different spot on the muffler , and the stock pipes come more straight back. not much you can do. playing with them gets them more in the center but still way off the middle, which is what I wanted, and wanted for all of the ones I installed, it just doesn't work, at least I haven't found a way. I wound up going with a D&D fatcat and a ghost pipe, now its in the middle
Old Jul 30, 2013 | 08:52 PM
btsom's Avatar
btsom
One simple thing you can try for free. Loosen the clamp on the front of the muffler and rotate the muffler counter clockwise (looking at the back of the muffler as in the picture) and see if that doesn't center it a bit better in the space provided. Whether it does or not, don't forget to re-tighten the clamp. There is another way to explain this if this isn't clear.
